Activity › Forums › Apple Final Cut Pro Legacy › XDCAM in FCP6
XDCAM in FCP6
Posted by Laurie Gibbs on September 1, 2010 at 1:14 pmHello,
I am planning on shooting on a PMW-EX3 and editing in FCP 6.
Has anyone had any experience editing XDCAM EX in FCP 6? Does the native codec work with this version of FCP or will I have to transcode the footage before I can begin editing?
Thanks in advance,
Laurie
Sachin Desai replied 16 years ago 4 Members · 7 Replies -
Sachin Desai
September 1, 2010 at 3:37 pmI’ve edited xdcam ex but of jvc 700. But if you can upgrade fcp to 7 it works fine.
Sachin Desai
Laurie Gibbs
September 1, 2010 at 3:40 pmThanks Sachin,
Unfortunately, I haven’t got the budget to upgrade at the moment. Thanks for the response though.
Laurie
Shane Ross
September 1, 2010 at 5:57 pmJust make sure that you are fully updated to 6.0.6…then you should be fine.
Shane
Read my blog, Little Frog in High Def -
Sachin Desai
September 3, 2010 at 2:10 pmyou can still edit it in fcp 6 only thing you want be able to do is take your timeline to color…
it will edit smooth in fcp 6 also
all the best
Sachin Desai
Rafael Amador
September 3, 2010 at 5:23 pmEX footage is supported since FC 6.0.2.
[Sachin Desai] “you can still edit it in fcp 6 only thing you want be able to do is take your timeline to color…”
No really. You can send your Time-line to Color.
What you can’t do is to import the files directly from your media HD.
With FC 7 is possible ingest the files directly without sending from FC.
Cheers,
rafael -
Sachin Desai
September 4, 2010 at 4:27 pmI was not able to, when i sen my time line in older color version (1) it only displayed red cross…
see whats new in color 1.5
anyways thats not the issue here…editing xdcam in fcp 6.xx is smooth …
Sachin Desai
