Activity Forums Apple Final Cut Pro XDCam import question
  • XDCam import question
    Posted by Bret Williams on May 8, 2013 at 6:07 pm
    Seems like every month there’s some new flavor of XDCam I can’t import natively.
    A few weeks ago I was able to download the plug-in from Sony and the updates from Apple and import XAVC no problem.
    Today I just got a drive which is supposedly XDCam. Shot to disc. Not familiar with disc structure. But they send us a drive. It simply has a folder called clip, and inside that folder there is nothing but mxf and xml files. None of which can be read by fcpx or the finder.
    XDCam transfer will convert them to XDCam movs however, so it’s not really a problem. Just wondering if I’m missing something or if the camera op didn’t send the full structure. Since I’ve got all the updates to X and the sony plug-in that allows xdcam and xavc and it works with xavc, I’m guessing I didn’t get the full file structure.
    Bret Williams replied 13 years, 3 months ago 3 Members · 4 Replies
  • John Godwin
    May 8, 2013 at 10:22 pm
    Bret,
    I’m pretty sure that isn’t the full directory structure …
    Best,
    John
  • Bret Williams
    May 8, 2013 at 11:51 pm
    Yeah – I figured. Lucky xdcam transfer had no problem.
  • Matias Canelson
    May 9, 2013 at 1:42 am
    If it was a F5, the card structure is this:
    MatiasCanelson
    http://www.canelson.com.ar
  • Bret Williams
    May 9, 2013 at 2:53 am
    PDW700
    And all I got was a clip folder.
