Activity Forums Apple Final Cut Pro Legacy XDCAM HD with FCP 5.1 – output via firewire for downconverted SD monitoring
  • XDCAM HD with FCP 5.1 – output via firewire for downconverted SD monitoring
    Posted by Mark Stuart on February 2, 2007 at 12:13 am
    I am editing an XDCAM HD project on FCP 5.1 with a dual 2.5ghz G5 Mac.
    Enabling Digital Cinema Desktop Preview plays full frame rate and full screen on my 1600×1200 2nd display.
    I prefer to monitor on a Sony CRT PAL studio monitor that I am used to so I now enable video playback using the Apple Firewire PAL setting.
    The output I get is single frame, despite being set to all frames. Also the aspect ratio is wrong, it is more squashed closer to cinema 2.35:1
    Is anyone editing HD material on FCP and managing to get an SD downconversion via firewire? without need for a Kona card?
    Many thanks
    Regards
    Mark
    Mark Maness replied 19 years, 7 months ago 3 Members · 2 Replies
  • Andrew Commiskey
    February 2, 2007 at 4:31 am
    I cannot figure any way to use firewire but a basic Decklink card will down convert (great if you can find it used) Standard Definition works.
    Drew
    Chaos is the beginning of everything.
  • Mark Maness
    February 2, 2007 at 8:49 pm
    Sorry…. That’s not going to work like you want it.
    Anytime you work in HD or HDV, you really need to have a broadcast HD monitor. AJA Kona is the best method, in my opinion. But I’m sure that the Blackmagic Decklink will be fine also.
    What are you sing to ingest your video? Camera or F70 deck?
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
