Activity Forums Avid Media Composer XDCAM HD 1080i
  • XDCAM HD 1080i
    Posted by Mike Piazza on February 16, 2010 at 1:56 am
    Hi my workflow is such
    Capture and edit in HDV 1080I then output to XDCAM HD 1080I with Captions . can this be done via Media Composer 4 via Firewire?
    will it be 1080I .
    can this deck be used? PDW-U1
    or do I need the more expensive one?
    Mike
    Mark Ciesinski replied 16 years, 6 months ago 3 Members · 4 Replies
  • Ed Cilley
    February 16, 2010 at 4:17 am
    The PDW-U1 is a player only. You can’t even write metadata back to the disc. This deck is only USB.
    Yes, you will need to step up to something like the PDWF75. I haven’t done anything with Captions, but you could check Sony’s site.
    https://pro.sony.com/bbsc/ssr/cat-videorecorders/cat-recxdcam/product-PDWF75/
    Hope this points you in the right direction.
    Ed
    Avid and FCP Preditor
    _________________________________________________
    Anything worth doing at all, is worth doing well.
    – Philip Dormer Stanhope, Earl of Chesterfield
  • Mark Ciesinski
    March 1, 2010 at 1:57 pm
    You can write back to the PDW-U1 but first you will have to do a firmware update that you can get here:
    https://pro.sony.com/bbsc/ssr/micro-xdcam/resource.downloads.bbsccms-assets-micro-xdcam-downloads-XDCAMSoftwareDownload.shtml
  • Ed Cilley
    March 8, 2010 at 8:16 pm
    Mark,
    So I downloaded from the link, confirmed all was good, installed the Firmware upgrade and now the PDW-U1 doesn’t see any clips on the disc (or any disc). I can see clips on the 75 deck, but not the U1, so I know it’s not a disc issue.
    Any ideas?
  • Mark Ciesinski
    March 9, 2010 at 1:28 pm
    I don’t know if this will solve your problem but whenever I put a new disc in the PDW-U1 and i click on import the disc reader is not seen the first time. I have to cancel out of that and try to import again and then the disc drive is recognized.
    hope it helps.
