Activity Forums Creative Community Conversations xdcam files import
  • Posted by Dan Jones on February 19, 2012 at 4:56 pm
    Hoping for an easy solution:
    I am having trouble importing XDCAM files that I have on my Mac Book Pro(I no longer have the files on SxS card), into Final Cut Pro X.
    I have downloaded the most recent Mac and Sony XDCam Transfer files, but I can’t make the Transfer software move the files to Final Cut Pro X.
    Thanks in advance.
    Dan Jones replied 14 years, 6 months ago 5 Members · 13 Replies
  • 13 Replies
  • Lance Bachelder
    February 19, 2012 at 5:57 pm
    I had to use the Sony software as a stand-alone to re-wrap XDCAM to QT’s and then import to FCPX. I think Sony will be showing FCPX compatible version at NAB in April.
    Lance Bachelder
    Writer, Editor, Director
    Irvine, California
  • Steve Connor
    February 19, 2012 at 5:58 pm
    What format are they in?, are they in the original BPAV folders?
    The latest XDCam transfer does not put the files into FCPX, you need to set a folder for the software to unwrap the files to and then import the files into FCPX manually
    Steve Connor
    “FCPX Agitator”
    Adrenalin Television
  • Dave Jenkins
    February 19, 2012 at 8:26 pm
    You want to use the XDCAM Browser 2.0.
    As Lance said, you need to set a folder for the software to rewrap the files to and then import the files into FCPX manually.
    Dajen Productions, Santa Barbara, CA
    MacPro Two 2.8GHz Quad Core – AJA Kona LHe
    FCS 3 OS X 10.6 QT 10
  • Dan Jones
    February 20, 2012 at 2:05 pm
    Thanks so much.
    Just to clarify, in Clip Browser I should export using “MFX for NLEs….”?
    And then import manually into FCP X?
    Thanks again.
  • Kevin Patrick
    February 20, 2012 at 3:30 pm
    I use XDCAM Transfer. Not Browser.
    In the Source Pane on the left, you pick your source.
    In Preferences (odd place) you pick the location you are Importing to.
    Select your clips and hit Import. (lower right)
    The Import process re-wraps the clip(s) as *.mov file(s) and FCP X will import them into an Event.
    I’m assuming you can do this with XDCAM Browser, but I’m not sure how. I use XDCAM Browser to make backups of the XDCAM files/directory. Make sure you turn on the error checking option. I don’t think it’s on by default.
  • Dan Jones
    February 20, 2012 at 4:48 pm
    FCP X is saying that it cannot open the .mov files. It gives me a dialogue box for each individual clip saying so.
    Transfer is putting the files into the folder as .mov and .xml.
  • Steve Connor
    February 20, 2012 at 4:59 pm
    Have you downloaded the codecs using the “Download additional content” command in the File menu of FCPX?
    Steve Connor
    “FCPX Agitator”
  • Kevin Patrick
    February 20, 2012 at 5:25 pm
    [Steve Connor] “Download additional content”
    I did this so long ago, I can’t recall if I needed this for XDCAM or not. But I didn’t think the additional content provided codecs.
    Isn’t this what you get with additional content?
    https://support.apple.com/kb/DL1394
    Here’s what Apple says about XDCAM and FCP X.
    https://support.apple.com/kb/HT4724
    I believe it is suggesting what I mentioned. Simply use XDCAM Transfer and Import the files. XDCAM Transfer should simply create the *.mov files that FCP X needs. No additional codecs necessary. Simply a re-wrap of the BPAV files.
    Am I missing something here?
  • Kevin Patrick
    February 20, 2012 at 5:27 pm
    [dan jones] “Transfer is putting the files into the folder as .mov and .xml.”
    Something does not sound right.
    When I execute the Import function on XDCAM Transfer, it only creates one file for each clip, a *.mov file. It does not create any *.xml files.
    Are you sure you are using XDCAM Transfer, not Browser?
  • Dan Jones
    February 20, 2012 at 6:09 pm
    I am using Transfer.
    The files are on the hard drive and not on SxS cards. Could that be the problem?
    I have updated all codecs. When I start the import in XDCAM Transfer, it creates the .mov files in the destination folder, but it opens FCP and I get this pop up message for each file:
    The document “489_1244_01.mov” could not be opened. Final Cut Pro cannot open files in the “QuickTime movie” format.
