Activity Forums VEGAS Pro XDCAM Explorer Issue
  • XDCAM Explorer Issue
    Posted by Douglas Hess on August 13, 2008 at 2:11 pm
    I just started a new project and it’s from SONY XDCams. When I try and use the explorer so I and use the proxy files instead of the full render versions it says:
    0 clips match the current view setting out of 32 total clips on the disc. Relax the view essence mark fileter to see all clips.
    I’ve tried every setting there is- turning them on and off- and still get the same message. Any ideas.
    Eugene Kosarovich replied 18 years ago 2 Members · 3 Replies
  • Eugene Kosarovich
    August 14, 2008 at 8:28 am
    What is your “view” setting in XDCAM Explorer set for?
    You should have it set for “All Essence Marks.”
    This is in the toolbar of the XDCAM Explorer window.
    Scorpio Productions
  • Douglas Hess
    August 14, 2008 at 11:42 am
    That is the setting I have it on and just to make sure, I went through and tried all of the other settings. I also opened the “All Essence Marks” setting (which it was defaulted to anyway) and tried combinations of checking and unchecking the boxes all to no avail.
    Doug
  • Eugene Kosarovich
    August 14, 2008 at 6:54 pm
    Does it work if you bring in the full resolution clips?
    Scorpio Productions
