Activity › Forums › Sony Cameras › XDCAM EX SD card file structure problem
  • XDCAM EX SD card file structure problem
    Posted by Chris Gurney on April 18, 2012 at 8:45 am
    I often freelance for the BBC regional news.
    Their workflow consists of shooting on a PMW-500 (at 35 Mbps) onto SD cards via an SxS adapter.
    After the shoot the SD card is inserted into a card reader and the shots appear on the FCP 7 log and transfer window. Their SD cards have a root file structure of /BPAV
    When I work for them, I use a PMW-350, a Sony MEAD-SD01, and one of their SD cards. The problem is my shots don’t appear in FCP’s log and transfer window as the file structure is /PRIVATE/SONY/BPAV and FCP is looking for the BPAV file. I presume this file structure is being generated by the 350 when I format the card in the camera.
    I know there are many ways of working round this, but I’m wondering if there’s any way I can get the 350 to write the BPAV file to the root directory of the SD card so that I fit into the BBC’s workflow more seamlessly.
    Any ideas gratefully received…
    Ian Cook replied 14 years, 5 months ago 2 Members · 1 Reply
  • Ian Cook
    April 20, 2012 at 2:41 am
    SD cards and Memory Sticks can only be formatted with a /private directory. This can’t be changed, unfortunately. I believe it’s a media requirement that goes beyond what the camcorder is doing…
