Activity Forums Adobe Premiere Pro XDCAM EX Export
  • XDCAM EX Export
    Posted by Aaron Cadieux on February 29, 2012 at 3:00 pm
    Simple Question,
    Can CS5.5 natively export in the XDCAM format? By XDCAM I mean being able to put the exported file back on the memory cards of an XDCAM camera and having the camera be able to read the file?
    Previous versions of Premiere could not do this.
    Aaron
    Richard Knight replied 14 years, 6 months ago 2 Members · 2 Replies
  • Aaron Cadieux
    February 29, 2012 at 5:38 pm
    Hello,
    I am going to making a jump from CS3 to CS5.5. In order to do that, I will be building a new dual Xeon Quad-Core 64 bit PC this spring. Some of this “Dream Machine” is based off of using B&H’s Adobe Production Suite optimized turnkey editing PCs. By building my own machine, I found that I can significantly improve on many aspects of the B&H machines and still stay well below their price. Here are the components I’ve picked out for my dream machine.
    3.06GHz Intel Xeon Quad-Core (Bloomfield) – 2 for $610
    nVIDIA Quadro 4000 with 2GB RAM – $726
    Intel 510 Series (Elm Crest) SSDSC2MH120A2K5 2.5″ 120GB SATA III MLC
    Internal Solid State Drive (SSD) – $239 (will be primary drive)
    EVGA Classified SR-2 270-WS-W555-A2 LGA 1366 Intel 5520 SATA 6Gb/s USB 3.0 HPTX Intel Motherboard – $550
    G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-8GBRL – 6 for $240
    Blackmagic Decklink SDI – $295
    Microsoft Windows 7 Professional SP1 64-bit
    With this machine, I will be editing my projects on a Lacie 4Big Quadra external array connected via eSATA. I have the array set to RAID10.
    I guess my first question is, will this machine effectively run Adobe Production Suite CS5.5?
    My second question is in regards to RAM. I have the motherboard maxed out at 48GB of RAM. Obviously the machine itself will run like a clock with that much RAM, but how much of that RAM will the Adobe software bundle actually be able to utilize?
    I posted this in the Premiere forum, because that’s the software that I’ll be using the most on this machine.
    Thanks and I look forward to hearing your responses.
    -Aaron
  • Richard Knight
    March 1, 2012 at 5:47 pm
    No
