Activity › Forums › Apple Final Cut Pro Legacy › XDCAM EX 720p50 slow mo
Posted by Gergo Szabo on September 21, 2010 at 6:46 pmHello,
I have shot some clip with the SONY EX1R in 720p 50fps and 25fps. I would like to mix it like the 50p clips would be slower than the 25p. I have made a ProRES 720p25 timeline and Imported the 50p clip to it but It’s normal speed.
Do you have any idea?
GaryGergo Szabo replied 15 years, 11 months ago 4 Members · 5 Replies -
Stephan Walfridsson
September 21, 2010 at 7:03 pmOpen your 50fps clips in Cinematools and use the Conform option to change the speed to 25fps.
/Stephan
Gergo Szabo
September 21, 2010 at 7:52 pmThanks for the fast answer. At the time I have found a video tutorial on this site. Only thing I had to do the Recompress the clip to ProRES 422.
Best Regards
Gary -
John Fishback
September 21, 2010 at 8:30 pmHere’s a tutorial by Shane Ross how to use Cinema Tools to do what you want.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)Pro Tools HD w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
Rafael Amador
September 22, 2010 at 1:07 am[Gergo Szabo] “Thanks for the fast answer. At the time I have found a video tutorial on this site. Only thing I had to do the Recompress the clip to ProR”
Hi Gergo,
Yes, you need to transcode first, because CinemaTools can not run in GOPs stuff.
BE CAREFUL and duplicate the clips that you want to slow down. The “Conforming” has no way back.
Rafael
