Activity › Forums › Apple Final Cut Pro › XDCAM EX 35mbps issue with fcpx
Posted by Goutom Ain on February 25, 2016 at 7:18 pmDear Member,
When i import XDCAM EX 35 mbps .mp4 clip in fcpx, clip shows green. please help.
Goutom Ain replied 10 years, 7 months ago 4 Members · 7 Replies -
Francois Jean
February 25, 2016 at 8:56 pmWhy do you prefer to import the mp4 clips instead of the real XDCAM EX clips? The xdcam clips are much better quality can be used directly in FCPX via the import window…
Francois
Noah Kadner
February 25, 2016 at 11:47 pmDon’t drag in the MP4s- import the entire card via the Import Window.
Noah
FCPWORKS – FCPX Workflow
FCP Exchange – FCPX Workshops -
Goutom Ain
February 26, 2016 at 5:50 amHi, Thanks for the reply.
In my case importing card will take transcoding time, and multiple editors worked with a single card time to time. Hence I thought of giving them the transcoded format. -
Noah Kadner
February 26, 2016 at 6:40 amYeah but what you are working with is the low quality proxy. The only way to get the actual full resolution original is via ingest/transcode.
Noah
Goutom Ain
February 26, 2016 at 6:47 amI am using an application to ingest the clips. But the application i am using to ingest the SDI source is giving me .mp4 file with XDCAM EX 35mbps but if i select XDCAM HD 50mbps I am getting mxf file which is playable in fcpx. I want to use 35 mbps just to save some space.
In which I can say the mp4 clips are also high quality but more compressed.
Please suggest
Tony West
February 26, 2016 at 3:14 pm[Goutom Ain] ” am using an application to ingest the clips. “
Are you using the SONY Transfer app?
