Activity Forums Apple Final Cut Pro Legacy XDCAM EX 1080p 24
  • XDCAM EX 1080p 24
    Posted by Elie Mosseri on October 19, 2011 at 3:49 am
    I am editing a project shot as XDCAM EX 1080P 24. As we all know these are MPEG2 compressed files. Anyways it looks fine when editing but now I am compressing the project to be a DVD and I am getting compression artifacts especially over interviews shot on a black background. I am using compressor to create the MPEG2 file using the 90min compression setting set by apple. Is there a way to get around this problem? I have tried making the timeline a prores timeline in hopes of clearing this up, but it did not resolve the problem. Any suggestions would be very much appreciated.
    Rafael Amador replied 14 years, 11 months ago 2 Members · 5 Replies
  • Rafael Amador
    October 19, 2011 at 4:27 am
    Are you setting “Frame Control ON” in Compresssor, and Best downscaling?
    rafael
    http://www.nagavideo.com
  • Elie Mosseri
    October 19, 2011 at 11:16 am
    No I have not I will give that a shot.
  • Elie Mosseri
    October 19, 2011 at 11:31 am
    Yes on frame control cannot find the setting for best down scaling.
  • Rafael Amador
    October 19, 2011 at 3:58 pm
    In the resize filter set BEST.
    rafael
  • Rafael Amador
    October 19, 2011 at 4:06 pm
    Hi Elie,
    Sorry i was in a hurry when I’ve answered your post.
    If you want to get the best of your EXDCAM stuff, once you have your sequence ready to export:
    – Change the sequence codec to Prores or Prores HQ.
    – Set Render all YUV material in High Precision.
    Export the movie and then import to Compressor.
    Apply the DVD preset as you did it, with the frame Control ON and the Best Resizing.
    depending of the length of the movie, you can increase the data rate to get a better compression.
    rafael
