Activity Forums Apple Final Cut Pro Legacy XDCAM – DPX with super whites ?
  • XDCAM – DPX with super whites ?
    Posted by James Mortner on August 17, 2010 at 3:20 pm
    Hello all COW-ers,
    Anyone had some experience doing this ?
    Ive conformed an XDCAM sequence, media managed all the shots into separate chunks and exported to DPX. Except the DPX files are clipped at 0-100 where the original shots went right to 125.
    Is this a shortcoming of gluetools ? Is there a way around ?
    Many thanks
    James Mortner
    James Mortner replied 16 years ago 2 Members · 4 Replies
  • Gary Adcock
    August 17, 2010 at 4:27 pm
    [James Mortner] “Ive conformed an XDCAM sequence, media managed all the shots into separate chunks and exported to DPX. Except the DPX files are clipped at 0-100 where the original shots went right to 125.”
    Sure that’s not 115 IRE?
    I do not know of too many cameras that can record to 125 IRE, and non of them are ENG style.
    Since you do not say how or with what that you handled this process we are all left to guess.
    My guess is that you messed up and left a broadcast safe setting ON somewhere ( like in COLOR)- but without a workflow it is impossible to be sure.
    gary adcock
    Studio37
    Post and Production Workflow Consultant
    Production and Post Stereographer
    Chicago, IL
    https://blogs.creativecow.net/24640
  • James Mortner
    August 18, 2010 at 9:11 am
    Sorry, I havent given you enough details here.
    I was supplied an FCP project with XDCAM media which all reconnected a-ok. I then media managed the conform into separate XDCAM QT files. All well and good. However, when using compressor and gluetools to export DPX files it seems to clip the luminance at 100% where the source went all the way to 107%. I was using a 10bit raw colour export setting in gluetools.
    Is there a way to export DPX files with the luminance preserved ? Do i need to export with a new white point so as to preserve levels within 100% ?
    Phew
    Many thanks
  • Gary Adcock
    August 18, 2010 at 1:45 pm
    [James Mortner] “Is there a way to export DPX files with the luminance preserved ? Do i need to export with a new white point so as to preserve levels within 100% ?”
    You missed a setting in compressor, or it could be in your GT Prefs.
    what are your settings in the GT prefs pane?
    which compressor settings did you use.
    Like I said you missed a setting somewhere that truncated the color space to “broadcast safe”
    gary adcock
    Studio37
    Chicago, IL
  • James Mortner
    August 18, 2010 at 3:39 pm
    I used ’10bit Raw Image data’ setting on compressor and the GT prefs pane has the same.
    I don’t see how broadcast safe comes into it as the footage is QT files straight into compressor, no FCP colour space applied ?
