Activity Forums Apple Final Cut Pro Legacy XDCAM downconvert sequence settings
  • XDCAM downconvert sequence settings
    Posted by Rodney Spottiswood on April 6, 2011 at 2:25 am
    I’m wondering if anyone can confirm the correct sequence settings for me when down converting XDCAM to SD.
    I’m working in PAL with XDCAM HD422 1080i50 (50mb/s) footage and needing to edit in SD for a few reasons (intercutting with SD material but XDCAM footage is the bulk of the footage).
    I’m putting the footage into a sequence set to:
    720×576 (CCIR 601/DV PAL 5:4), anamorphic, upper field and Apple Pro Res 422.
    The footage has to be rendered before outputting but looks fine.
    I’m not sure whether I actually need to be setting my sequence to 768×576 square pixels or whether I should convert my footage to Apple Pro Res in compressor prior to the edit (which is time consuming & uses extra drive space).
    Any thoughts?
    Rodney Spottiswood replied 15 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
