Activity Forums Blackmagic Design XDCAM & DL Extreme – no signal.
  • XDCAM & DL Extreme – no signal.
    Posted by Margus Voll on November 16, 2006 at 12:32 am
    Hi.
    I had problems from capturing from XDCAM deck.
    I used SDI in as with Digibeta.
    Problem only ocured with xdcam – no signal.
    Digibeta worked as a cloc work.
    No external synq in both cases.
    When i played disk in jog / shuttle mode with speed +1 then i saw signal
    and could capture but with out timecode and device control.
    Can enyone tell if this is some sort of compatibility issue
    or just this particular xdcam player is bad ?
    Margus
    https://iconstudios.eu
    Margus Voll replied 19 years, 10 months ago 2 Members · 3 Replies
  • Kristian Lam
    November 16, 2006 at 3:34 am
    Hi Margus,
    Please try turning off UMID on your VTR.
    regards
    Kristian Lam
    Blackmagic Design
  • Margus Voll
    November 16, 2006 at 1:41 pm
    Hi.
    I’ll get to test this device again in couple of days.
    What does this UMID do ?
    Margus
  • Margus Voll
    November 19, 2006 at 8:06 pm
    Hi.
    UMID was deffinetly the thing that worked 🙂
    Margus
