Activity Forums Apple Final Cut Pro Legacy XDCam audio question
  • XDCam audio question
    Posted by Jussi Buckbee on March 31, 2008 at 8:43 am
    Has anyone had any problems with XDCam audio and FCSP2? Here’s what’s happening
    with my material. I import with XDCam Transfer (imx50 PAL), take the material into
    my project and start editing. I constantly run into audio beeps because my timeline shows
    that audio needs to be rendered. I look at the clips in Browser and audio shows “32-bit floating”. I cannot replicate those audiosettings in my sequence settings. Only options I have
    are 8-bit. 16-bit or 24-bit. Any ideas?
    br…jb
    Intel Mac dual 3.0 / 8 GB RAM / internal sata 2.0TB / Kona LHe / FCSP 2 / QT 7.3
    Mark Maness replied 18 years, 6 months ago 2 Members · 1 Reply
  • Mark Maness
    March 31, 2008 at 3:05 pm
    Set your realtime audio to more than the default setting. Depending on you computer and amount of RAM you have, the realtime audio can be set up to 99 tracks.
    To do this…
    Go into your Sequence. Look at the buttons on the upper right corner of your sequence window. Right-Click or Command-Click and click on Show Button List. A new window will pop open. Scroll thru this window until you see the Audio list. Click on the arrow beside the word Audio to open its list. Scroll to the bottom of the Audio list an you’ll see a set of command that say Realtime Audio Tracks. There will be several buttons. Click on any one of them and drag it to the Button area of your sequence window. You’ll notice that it drags several buttons to it. This is normal for this.
    Now, just select a button until you get your realtime audio and the audio rendering will disappear.
    It’s just that easy. Good luck!
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
