Activity › Forums › Apple Final Cut Pro Legacy › XD CAM transfer causes FCP crash
Posted by Steve Cain on October 6, 2009 at 8:49 pmWhen trying to import XDCAM files thru FCP, each time I click on SONY XD Cam in the import menu, FCP crashes.
Using XDCam app 2.9.0
StevePowerPC G5
Dual 2.3
3GB ram
FCP 6.06Vijay Tomar replied 16 years, 11 months ago 6 Members · 11 Replies -
Christopher Hill
October 6, 2009 at 9:17 pmI’m assuming that you’ve already downloaded the plug-in required to Log and Transfer XDCam footage using FCPro, if not you can find it here.
https://www.sony.ca/xdcamex/software.htm
If you already have the plug-in, there is also Sony’s XDCam Transfer and XDCam EX Clip Browser software you can use to convert the footage to another FCP friendly format.
Steve Cain
October 6, 2009 at 9:55 pmI have used the XDCAM transfer app to wrap the EX clips, then imported those clips into FCP browser without a problem. I thought it should be a one-step process from FCP, and shouldn’t cause FCP to crash, and therefore wondered if there is a problem with the computer, the program, or the operator.
Rafael Amador
October 7, 2009 at 1:51 am[Steve Cain] ” I thought it should be a one-step process from FCP,”
It should be.
Trash your FC Preferences and see if its works.
Rafael -
Steve Cain
October 8, 2009 at 1:28 pmTrashing preferences made no difference. I spoke to Sony some time ago about this problem, and they could not figure it out either. I am just wondering if anyone else had ever had this occur.
Stuart Simpson
October 12, 2009 at 1:27 pmLatest build of XDCAM Transfer is 2.10.0 – might be worth updating.
-Stuart
7 MacPros – Kona 3, Kona LH & Kona LHi
1 G5 – Kona LH
xbox360, Wii, PSP, PS3
https://www.speak.co.uk -
Vijay Tomar
October 26, 2009 at 1:33 pmi have never worked with xdcam ex3 media.
got a 2.6 intel core 2 duo Macbook Pro, Mac OS 10.5.6 with FCP 6.0.5
need to know how to go about it. -
Steve Cain
October 26, 2009 at 3:21 pmDownload the xdcam transfer application from Sony:
https://servicesplus.us.sony.biz/sony-software-model-XDZP1.aspxOnce installed, from FCP import clips from Sony XDCAM which will be an option in your import menu.
Mary Zahran
October 27, 2009 at 5:16 pmi have this problem. i tried everything to fix it. i still can’t get it to work. as soon as i open the log and transfer – crash- xd cam plugin error-
i just use my laptop to transfer now… annoying. -
Steve Cain
October 27, 2009 at 8:27 pmThanks — nice to know I have company in my misery! What equipment do you have, and are you transferring directly from the camera or from a hard drive to which the files have been transferred?
Steve -
Mary Zahran
October 28, 2009 at 2:38 pmMac Pro Quad-Core Intel Xeon, 3.2 GHz, 8 GB memory-
i have tried both from camera and from drive with card transferred.
i even had support come in – and he couldn’t figure it out either…
grrr
