Activity Forums Sony Cameras XD CAM IMPORT ERROR TO FCP
  • XD CAM IMPORT ERROR TO FCP
    Posted by Annu Lilja on May 25, 2008 at 8:02 am
    I have a lot of XD CAM material that I have imported to final cut using XD CAM TRANSFER.
    Some clips won’t transfer, though. These are clips starting with SMI, or subclips of these clips.
    One error message I get is:
    NSFC Data writeTo File:options:error:
    nil file argument
    Other times the program suggests that my drive is too full, which is not the case.
    PLEASE HELP!
    Thank you.
    Annu
    Robert Dexter replied 18 years, 3 months ago 3 Members · 2 Replies
  • Michael Palmer
    May 25, 2008 at 4:29 pm
    I believe you have clips that either were over 4 gigs or have crossed to another card.
    In the case of a clip being over 4 gigs you will see the SMI file and perhaps 2 files that end with -1 then -2, highlight the clip and down in the information box, i believe under the subclip you will see a check box for these clips, make sure they bother are checked. If you have clips that have crossed to a second card you will need to add an end mark to the first half as if you were making a subclip.
    Good Luck
    Michael Palmer
  • Robert Dexter
    May 27, 2008 at 7:14 am
    What version of XDCAM Transfer were you using?
    This trouble might have been fixed in the latest version 2.7, which you could get from here:
    https://www.sony.co.uk/res/attachment/file/41/1203501582241.dmg
