Activity › Forums › Adobe Premiere Pro › xbox one to adobe premiere
Posted by Tareq Faroun on January 16, 2017 at 9:41 pmHow would one go about capturing from Xbox one to Adobe Premiere on a IMac mid 2011? I have not done this in a long time, I used to have a simple Canopus digital converter back in the mini DV tape days, I hooked it up to my PS2 to play DVDs and capture as a non controllable device to make my own movie trailers. I am sure the technology has changed since then, or do I still need a digital converter?
Thanks in advance for your input and advice.
Andy Patterson replied 9 years, 8 months ago 4 Members · 7 Replies -
Andy Patterson
January 16, 2017 at 10:41 pmThere are several high-definition video capture cards on the market. The Blackmagic Design Intensity Shuttle is not the easiest capture card to use but it can allow for real-time playback from the Adobe Premiere Pro timeline to broadcast monitors. I use it more for real-time playback to broadcast equipment than capturing video. Most of the other inexpensive capture cards will not work with high-end video editing software. I like using my Intensity Shuttle but you might opt for something else.
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Tareq Faroun
January 16, 2017 at 10:57 pmIs there any encryption issues that would block the DVD from being captured?
Shane Ross
January 16, 2017 at 11:00 pmHDMI out of X-BOX and PS4s have protection on them, no? Meaning that you need the decoder in the TV to see them. There are no decoders in the Blackmagic or other pro capture cards….you need something like:
https://www.ign.com/articles/2013/08/30/the-best-video-game-capture-kits-for-xbox-360-ps3-and-pc
When I had this issue, I ended up aiming a camera at the TV screen.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Tareq Faroun
January 16, 2017 at 11:15 pmI hope I’m not missing the point, please correct me if I misunderstood but as long as I can capture clips from the Xbox DVD player without any HDCP issues I’m good, not trying to stream, just capture specific clips to make my own trailers for movies.
Shane Ross
January 16, 2017 at 11:22 pm -
Andy Patterson
January 16, 2017 at 11:38 pm[Tareq Faroun] “Is there any encryption issues that would block the DVD from being captured?”
I think people have stated that if you use the component connectors instead of HDMI the Intensity Shuttle will work with the XBOX and Sony Play Station. I cannot test it out because I do not have and Xbox or Play Station. You might find a Youtube video that show the Intensity Shuttle doing game capture.
