Activity › Forums › Adobe Premiere Pro › XAVC Sequence Presets
  • XAVC Sequence Presets
    Posted by Susie Eisenberg on December 11, 2014 at 9:17 pm
    Just got a Sony FS7. I assumed that there would be XAVC sequence presets but I can’t find any. When I make a sequence from clips, it makes a AVC intra 100 time line, not XAVC. They’re similar but not the same. Does anyone know if there are XAVC presets? Maybe I’m just missing something. Any suggestions would be helpful.
    Ericbowen replied 11 years, 9 months ago 2 Members · 1 Reply
  • Ericbowen
    December 11, 2014 at 10:16 pm
    You can use any of the presets if the frame aspects and frame rate are correct. The Presets are just there to make selecting those frame features correctly. XAVC and AVCIntra are actually in the same family so those presets are fine if the frame rate is accurate. BTW the presets themselves do not change the way the media decodes. You can select custom for editing mode and it will handle any media Adobe supports.
    Eric-ADK
    Tech Manager
    support@adkvideoediting.com
