Activity › Forums › Adobe Premiere Pro › XAVC-S in Premiere Pro 6
Posted by Kasimir Zierl on July 23, 2019 at 6:57 amDoes Premiere Pro 6 handle XAVC-S files, I’m getting mixed messages that they don’t run well in Premiere Pro and need to be converted before use.
Is this really the case?
Kasimir Zierl replied 7 years, 2 months ago 3 Members · 5 Replies -
John Heiser
July 23, 2019 at 2:15 pmThe final version of CS6 shipped in 2012, while XAVC-S wasn’t introduced until 2013. You may have a hard time with those native files in CS-6.
John Heiser
Senior Editor
o2 ideas – Birmingham, ALiMac Retina 5k, 27-inch, 2017
4.2 GHz i7, 32GB RAM, Radeon Pro 580 8GB
G-Speed Studio TB-2 12TB RAID-5 -
Shane Ross
July 23, 2019 at 4:51 pmEven with a Premiere Pro version that supports that format, it’s a highly complex format that will require lots of computing resources to cut native. Fast processors, high end GPU. If your machine is older, or just “OK,” it’s better to transcode to an editing codec, like ProRes or DNxHD
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Kasimir Zierl
July 24, 2019 at 1:03 amhmm,
so if I downconvert to prores, is there a way to upconvert the footage when I export the final video? -
Shane Ross
July 24, 2019 at 7:25 amProRes isn’t a down convert. That’s a full-resolution format. Finishing format. The data rate is higher, the files will be bigger. If you want to do offline/online cutting, that’s…hmmm…well…not CS6’s strong suit. Not really designed for that…later versions are.
Gonna have to stick to converting to a high res finishing format and editing with that…ProRes.
Shane
Little Frog Post
