Activity › Forums › Apple Final Cut Pro › XAVC-L, all good in FCPX?
  • XAVC-L, all good in FCPX?
    Posted by Mark Morache on October 19, 2016 at 6:20 pm
    I’m considering buying a Sony FS5, which shoots in XAVC-L.
    Anyone using an FS5, or editing with footage from an FS5?
    Anything I should know about the workflow for this format?
    I don’t expect to be shooting a lot of 4k. I expect that at 100mpbs my MBP would be able to handle without going to proxy. I edit off of an external SSD which right now is connected with USB3, and it works great for XDcam HD.
    Thanks for the help.
    -Mark
    Mark Morache
    Evening Magazine, Seattle, WA
    Gerry Fraiberg replied 9 years, 11 months ago 5 Members · 5 Replies
  • Noah Kadner
    October 20, 2016 at 12:13 am
    I believe there’s a plugin from Sony you need and I would suggest optimizing media as Sony optimizes its codec performance more for acquisition than editorial.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
    XinTwo – FCPX Training
  • Giampaolo Moretti
    October 20, 2016 at 11:36 am
    We work a lot of XAVC-L footage but need proxy because always built a multicam clip with 8 tracks.
    The clips are on RAID-5 tower with Thunderbolt 2 and connected to MacPro 2013 8-core/AMD D500.
    The proxy work like a charm with all effects like color correction, slow motion, masks, ecc but when we switch to original XAVC-L there are lags, specially on clips with effects, rendering don’t help so much.
    Sometimes the footage are in XAVC-I and all is better
    http://www.metisfilm.it
  • Gerry Fraiberg
    October 20, 2016 at 8:41 pm
    I shoot in XAVC-L 50 mbps on a Sony PXW-X70 with no problem. When I first got the camera two years ago, FCPX didn’t support XAVC-L, and I had to use Sony Catalyst Browse to transcode to ProRes. But since then Apple has worked it out with Sony and all is well. I bought the 4K upgrade for the X70 to keep the camera future proof. My early 2009 vintage MacPro can’t handle 4K on a timeline, but dropping 4K onto a 1080 timeline works nicely – with no degradation on a Ken Burns push in.
    Here’s a sample: https://vimeo.com/139038852
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Craig Seeman
    October 20, 2016 at 10:29 pm
    Using the X70 both HD and UHD on 6 core MacPro Tube. Generally works well although I haven’t done multicam. I do get an occasional bad frame (macro blocks) which goes away if I slide the shot back and forth or trim a frame back and forth.
  • Gerry Fraiberg
    October 24, 2016 at 5:19 pm
    A plug-in from Sony is no longer required as FCPX now supports XAVC.
