Activity Forums DaVinci Resolve XAVC Intra UHD on a MXF delivery
  • XAVC Intra UHD on a MXF delivery
    Posted by Juan Carlos aguirre on October 9, 2015 at 9:11 pm
    Hello Everyone.
    I have a client request to deliver masters in XAVC Intra UHD on a MXF container.
    I anyone have a experience on it, and if there any way resolve can export in this format.
    In the specs, codec required is H264 at all, but not sure is we can conform on MXF.
    Any direction is very welcome
    Below is the full specs:
    Essence container MXF OP1a (SMPTE 378M)
    Video essence
    Essence format XAVC QFHD Intra (Class 300)
    Codec H.264 (AVC)
    Format profile High 4:2:2 Profile @ Level 5.2
    GOP I-frame only
    Bit rate Approx. 500 Mbps (VBR/CBG)
    Width 3840 pixels
    Height 2160 pixels
    Aspect ratio 16:9
    Frame rate 50 fps
    Scan type Progressive
    Chroma subsampling 4:2:2
    Bit depth 10 bits
    Audio essence
    Essence format AES-3 (SMPTE 382M, multi audio tracks, ungrouped)
    Audio coding PCM uncompressed
    Sampling rate 48 kHz
    Channel configuration 8 OR 16 audio tracks (1 channel per track)
    Bit depth 24 bits
    Juan Carlos Aguirre
    HTV Studio
    http://www.htvstudio.com
    ST Jang replied 10 years, 5 months ago 2 Members · 1 Reply
  • ST Jang
    March 31, 2016 at 2:12 pm
    As my experience, it has transcoding feature in Media management or , DaVinci Resolve,
    in case of DaVinci Resolve, it just transcoding with Non-drop Frame, it was different the way of edius and Davinci Resolve
    so you better check the quality between Davinci and Edius.
    I think Edius is better than Davinci, not sure
    Ritz Carltn
