Activity › Forums › Apple Final Cut Pro › x2pro says media still inaccessible even after i add…
  • x2pro says media still inaccessible even after i add…
    Posted by Jacob Brown on January 16, 2013 at 6:02 pm
    x2pro let’s me add the locations but still lists them as inaccessible below. i’ve tried adding after and before loading the xml. and i’ve logged out, restarted, ended the scoop process and all of that….
    anyone have similar experience?
    thanks!
    Jacob Brown replied 13 years, 8 months ago 3 Members · 3 Replies
  • John Davidson
    January 16, 2013 at 8:26 pm
    Maybe try adding the entire “LaCie 2” drive?
    John Davidson | President / Creative Director | Magic Feather Inc.
  • Charlie Austin
    January 17, 2013 at 5:29 am
    What John said… Add the root of every drive you need access to and you’ll be good to go…
    ~”It is a poor craftsman who blames his tools.”~
  • Jacob Brown
    January 17, 2013 at 4:26 pm
    ok so the problem had something to do with just working off an external drive.
    the xml file, media, and to-be-created aaf file were all on the external
    i figured this out because i noticed that x2pro was calling it lacie2 and it should have just been lacie
    so i moved the XML to my internal drive, and set the aaf to be exported on my internal, problem solved.
