Activity Forums Apple Final Cut Pro Legacy X + Y scaling in FCP
  • X + Y scaling in FCP
    Posted by Mike Faulkner on February 16, 2008 at 11:10 pm
    Hi everyone I wondr if you can answer this question
    If i scale footage with the shift key on in FCP [it does the opposite to After Effects] and does not keep the footage scaled in pro.
    If I go to the attributes of the footage is does not give me the x or y adjustments [as in After effects]. how can see this. is this a glitch in FCP?
    mike f
    Rafael Amador replied 18 years, 7 months ago 2 Members · 1 Reply
  • Rafael Amador
    February 17, 2008 at 4:02 am
    Hi Mike,
    In FC you don’t need to use the Shift key to resize keeping the x/y proportional. If you use the Shift key, what you are doing is distorting. Have a look in the “Distort” in the Motion tab to see how the value changes.
    PPC G5 2x2Gh 4GbRAM/BlackMagic SD/PMBP 17″Core2Duo 4GbRAM
    JVC DTV-17″/FCS2/AE CS3/COMBUSTION/SHAKE
