Activity Forums Apple Final Cut Pro X to 7 and R3Ds
  • X to 7 and R3Ds
    Posted by Eric Santiago on May 24, 2015 at 7:48 am
    Trying to get from FCPX to Premiere Pro CC 2014.
    Using Xto7 I can get the files over but only the audio works.
    The R3D clips are generic icons with question mark on it.
    Double click and you get the “Edit Offline” pop-up box.
    Need to sync audio in FCPX and then prep for Premiere.
    I cant get Premiere to merge audio sync these files using audio.
    Works with TimeCode but not all files got blessed.
    FCPX did the whole lot flawlessly.
    Eric Santiago replied 11 years, 3 months ago 3 Members · 20 Replies
  • 20 Replies
  • Oliver Peters
    May 24, 2015 at 10:36 pm
    When you highlight the RED clips and go to relink, can it relink to the RED files? Premiere should sync by audio just fine, but maybe it’s more problematic with the RED files.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Eric Santiago
    May 25, 2015 at 2:17 am
    Thanks Oliver that fixed it 🙂
    I had a duh moment and should have tried that.
    Due to recent workload and me trying to make Premiere the editor of choice for this movie has got the best of me.
    I still cant understand why the R3Ds dont sync with the audio when its flawless in FCPX.
    Of note, I also cant understand why I can only use the Media Browser to grab R3Ds. The Import tends to create the deep sub-folders 😛
    Thanks again crossing fingers if this will work for the editor 🙂
  • Eric Santiago
    May 25, 2015 at 2:21 am
    Well relink works but the Audio Sync didnt take.
    I see the Synchronized clips but they have no audio attached.
    The audio comes in separately but useless when trying to merge (again(.
  • Oliver Peters
    May 25, 2015 at 11:41 am
    Media Browser is set up to correctly interpret various file types. Finder imports simply read the OS file directory. As far as synchronized clips, XML translations are very hit or miss with multicam and synchronized clips. I’ve had a lot of grief this way. You might try syncing them in FCP X as multicam and see if that works better.
    Oliver
    Orlando, FL
  • Eric Santiago
    May 25, 2015 at 1:43 pm
    Thanks Oliver and yes I have synced them in FCPX which gives me a 99% success rate in the last year with R3Ds 🙂
    However the director/editor wants to use Premiere.
    I guess I can send these to Resolve via XML and then output to ProRes444@4K for Premiere.
    Any thoughts on this process?
  • Oliver Peters
    May 25, 2015 at 3:44 pm
    Sure, working in Resolve would also work, but you might want to tweak the raw settings before export if there are any issues. That way you won’t be constrained by not grading in raw should you need to adjust color temperature, for example. As a test at least, I would suggest syncing as multicam in X and see if that translates better into Premiere.
    Oliver
    Orlando, FL
  • Jeremy Garchow
    May 25, 2015 at 3:53 pm
    use RCX Pro to sync r3ds to Audio (by tc) and then shallow export to XML for Pr import and see if that works any better.
  • Eric Santiago
    May 25, 2015 at 6:01 pm
    Thanks Oliver and yes all R3Ds are checked in RCXPro first before hand.
    Thats the thing, I wish I could convince Director to use FCPX and keep the R3Ds intact.
    Jeremy I wish I can use TC across the board 🙁
    On average its about 15% of the project has timecode.
    They kept losing jam sync due to…who knows I wasnt on set 🙁
    With Resolve I can easily just select one clip (Media Pool) and apply TC and the whole lot with TC becomes synced.
    I wish FCPX had that.
    You still have to manually select each clip to apply that setting.
  • Jeremy Garchow
    May 26, 2015 at 12:44 am
    [Eric Santiago] “Jeremy I wish I can use TC across the board :(“
    I see. bummer. 🙂
    I am absolutely loving sync-n-link.
    Unfortunately there’s still a bug in fcpx when using 4k synchronized clips in a 1080 timeline where the 4k clips take on the 1080 raster properties. Not a show stopper, but really annoying.
  • Eric Santiago
    May 26, 2015 at 2:55 am
    Jeremy when I do anything with R3Ds I stay 1:1.
    Is this an issue when creating a 1080 project?
