Activity › Forums › Apple Final Cut Pro › X to 7 and premiere weirdness/warning
Posted by Bret Williams on April 1, 2013 at 4:46 pmHere’s an interesting one. I got Xto7 and am very impressed. What I’m not impressed about is how Premiere screws up my FCP X project afterwards.
I’m using xto7 to transfer a FCPX sequence to premiere. Works. But after Premiere has touched the project files, they are now marked as “modified file” in FCP X. It’s only the h264s FWIW. ProRes animation and stock footage and wavs are fine. WTF has Premiere done to the source media?
Jeremy Garchow replied 13 years, 5 months ago 4 Members · 25 Replies -
Oliver Peters
April 1, 2013 at 5:00 pmTurn off the XMP metadata settings in the import preferences for PPro.
– Oliver
Orlando, FL
http://www.oliverpeters.com -
Bret Williams
April 1, 2013 at 5:35 pmThanks! Too late now though…
Thankfully I was just playing with a completed consolidated project. So one more vote for “we need to fix this relinking crap and allow to force a relink!”
Bret Williams
April 1, 2013 at 5:39 pmI’ve got 2 –
Write XMP ID to Files on import (definitely turning that crap off)
But how about
Enable clip and XMP Metadata linkingWhat else can I turn off that is gonna screw up my system?
Oliver Peters
April 1, 2013 at 5:40 pmI think it’s just the “write XMP ID”, since that is modifying the source files.
– Oliver
Orlando, FL
Bret Williams
April 1, 2013 at 9:23 pmCan’t figure out what app that is. Get lots of ProTools links. Who makes it? Free?
Charlie Austin
April 1, 2013 at 9:39 pm[Jeremy Garchow] “QTEdit can strip XMP metadata out of Qt files.
“Just tried it on a file… didn’t seem to work. Fortunately it’s from a project that’s done, but if this had happened in mid job, I would be completely f*cked. Hope everyones sending feedback to apple about this, I have… Oh, and Bret, it’s part of Digital Rebellions’ pro media tools. a free trail is downloadable…
~”It is a poor craftsman who blames his tools.”~
~”The function you just attempted is not yet implemented”~ -
Bret Williams
April 1, 2013 at 10:55 pmYeah, this was a finished, consolidated project stil on the raid. I have the original camera files elsewhere, but it screwed up other stuff too, like AE renders and converted stock media. Going to be a pain in the a to repair it all. Probably 40 or 50 shots. One by one if the QTedit doesn’t work.
Charlie Austin
April 1, 2013 at 11:15 pm[Bret Williams] “Yeah, this was a finished, consolidated project stil on the raid. I have the original camera files elsewhere, but it screwed up other stuff too, like AE renders and converted stock media. Going to be a pain in the a to repair it all. Probably 40 or 50 shots. One by one if the QTedit doesn’t work.”
Bummer. i’m of 2 minds about this… One mind says that FCPX is being ridiculously anal about relinking. Which is probably true. If I cut from offline pix with window burns etc, and then want to relink a cut to final picture, with exactly the same TC and duration but in a different format etc, is that even possible? it should be. The old “This may blow up in your face. Do it anyway?” dialog. ;-}
The other mind says… what kind of idiotic app writes data to a master file without at least warning you it’s doing so? At least FCP 7 would say “you’re about to modify a source file. are you sure you want to?”
Oh well… more things to complain to Apple about. 🙂
Jeremy Garchow
April 1, 2013 at 11:57 pm[Charlie Austin] “Just tried it on a file… didn’t seem to work. Fortunately it’s from a project that’s done, but if this had happened in mid job, I would be completely f*cked.”
XMP file modification has been part of Adobe’s workflow for a long time so I usually shut off the XMP options (this has to be done in Ae as well).
In FCP7, XMP injection simply knocks render files loose, which can be a pain, but not devastating.
Reconnection in FCPX needs some retooling, absolutely.
FWIW, I have mistakenly left the option on, and the files flash that they are disconnected in FCPX, but then they relink. I don’t seem to have an issue of XMP knocking the files completely offline.
Stripping the XMP metadata works for me in Qt Edit.
Jeremy
