Activity Forums Maxon Cinema 4D X particles play dough
  • X particles play dough
    Posted by Mitch Eaton on August 20, 2018 at 11:06 am
    I’m trying to recreate playdough being pushed through holes similar to the start of this mtv ident.
    https://vimeo.com/193505103
    Not sure how to recreate this inside x particles.
    I’ve seen ej’s tutorial on soft body dynamics but it’s not quite right.
    Thanks heaps!
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Mitch Eaton replied 8 years ago 2 Members · 2 Replies
  • Brian Jones
    August 20, 2018 at 4:25 pm
    https://vimeo.com/122409448
    XPConstraints seems more like it but I don’t know how you would maintain the square corners that way. That MTV piece looks more like a square spline swept down a dynamic spline (with a big enough radius to keep from interpenetrating too much)…. someone had a plugin which the demo for looked quite a bit like that but I’ve unfortunately forgotten the name.
  • Mitch Eaton
    August 20, 2018 at 10:58 pm
    Yeah I was trying constraints earlier and it was close but not quite right.
    This one has been done in x particles which is similar as well.
    https://vimeo.com/230734768
