Activity › Forums › Apple Final Cut Pro Legacy › X in top right of canvas, no picture
  • Jerry Hofmann
    June 1, 2006 at 5:52 pm
    Check to see if the playback options in the oval button on the upper right side of the Canvas is set to RGB… if not, change it…. if this isn’t the problem, try trashing prefs…
    Jerry
  • Wayne Williams
    June 1, 2006 at 6:12 pm
    Thanx Jerry – Was set to Alpha Channel. Need to trash my prefs anyway. I had a plug-in for Panther that would dump prefs and restore to desired prefs. Doesn’t work in OS X. Got any ideas? Wayne . . .
  • Jerry Hofmann
    June 1, 2006 at 8:33 pm
    This one works: https://fcprescue.andersholck.com/
    Jerry
  • Wayne Williams
    June 1, 2006 at 9:06 pm
    Thanx Jerry – Life is good again
