Activity › Forums › Adobe Premiere Pro › WTH? No CTRL-M in CS3 anymore?
Posted by Tl Westgate on January 24, 2008 at 7:55 pmI am soooo used to hitting CTRL-M when exporting a movie. They did away with it, though! What else have they “improved” upon that you’re upset about?
Vince Becquiot replied 18 years, 8 months ago 2 Members · 5 Replies -
Tl Westgate
January 24, 2008 at 8:14 pmOh sweet! Thanks.
However, when I go to this, I highlight Export / Movie and nothing happens. There’s no “change this” button. If I hit my key combo nothing happens. I see shortcuts for some items, but there appears to be no way to set a new one.
The only buttons I see are OK, Cancel, and Save As. The ones below (Undo, Clear, and Go To) are greyed out.
Vince Becquiot
January 24, 2008 at 8:21 pmClick on the shortcut side in that row, the cell will turn white. You then simply hold ctrl+M
Vince
Tl Westgate
January 24, 2008 at 8:30 pmOh, okay. That worked. Is this non-intuitive or should I stop drinking at lunch?
