Activity Forums Maxon Cinema 4D wtf cluster and pivot
  • wtf cluster and pivot
    Posted by Eric Sanderson on November 18, 2011 at 9:16 pm
    So ive been getting familiar with using bones/point clusters/constraints for your cliche pop up book animation i have to do. So far so good except one thing. Why does my clustered geometry go crazy if i select my pivot tool?! Selecting (not even moving, simply selecting) my pivot on the object that has the cluster, ok ill give it that i could see that interrupting the deformer, maybe. BUT, no matter what layer im on, anywhere in my project if i select the pivot tool, any objects with clusters geometry goes haywire, and where it really screws me is undo doesnt fix it. Ive recently even saved my objects with cluster as an xref and EVEN THEN, as an xRef the geometry goes crazy if i select my pivot tool in my downstream project. Im using R13, has anyone had this issue? if so any tips? Im about to have to lost my clusters altogether because of it which im reluctant to do since im getting the exact result i need out of them (aside from making sure to never select my pivot tool)
    Eric Sanderson replied 14 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
