Activity › Forums › Apple Final Cut Pro Legacy › Wrong sequence settings… how to fix?
  • Wrong sequence settings… how to fix?
    Posted by Jason Caridi on November 26, 2011 at 8:57 pm
    So in a nutshell, I was stupid and have edited a music video with 1080p ProRes 4444 23.98fps clips in a 640×480 30fps sequence, and of course when I change the sequence settings or put them into a correct sequence, the clips are all small. Is there a way to fix this…?
    Transfer the clips on the timeline while keeping the placements and reusing the clips themselves, if ya know what I mean?
    Exporting it to 1080 30fps (or 23.98?) and using the master shots as a backdrop for the clips I want to composite over, hoping it won’t look too bad?
    Jim Murphy replied 14 years, 9 months ago 2 Members · 2 Replies
  • Jason Caridi
    November 26, 2011 at 9:00 pm
    OK I fixed it, sorry, I don’t even know how to delete posts now…
  • Jim Murphy
    December 12, 2011 at 2:26 am
    Can you explain to me how you fixed this? I have the reverse problem… stupidly created a sequence in 16:9 and footage is 4:3. Image is blown up when I change the setting to 4:3. Can you help?
