Activity › Forums › Adobe Premiere Pro › Wrong Save As…. Premiere Cs5
Posted by Hideaki Ogiwara on October 26, 2011 at 7:49 pmUnfortunately, I saved as my current project on the wrong session…
I didn’t back up auto-saved at all… Please let me know how I can get back before saving as this current session to be back to this morning session if someone knows…
I use windows 7 with premiere cs5
Thank you very much.Hideaki Ogiwara replied 14 years, 10 months ago 4 Members · 7 Replies -
Angelo Lorenzo
October 26, 2011 at 8:46 pmYou can try https://www.piriform.com/recuva to see if it’ll find your deleted autosaves, but if you browse the internet or work on other stuff, save other files, that space on your hard drive where the auto-saves were may have been written over already.
I don’t believe there are any autosaves or recoverable data in the AppData folder where they store the media cache, but I’m not a know-it-all either.
Hideaki Ogiwara
October 26, 2011 at 8:54 pmHi, Angelo Lorenzo.
I didn’t set-up auto-saved at all this time so I don’t know I can find some old session using this Recuva??
I may not sure still I can search old adobe session that I saved as on it using this….Please let me know any information if you know more!!
Angelo Lorenzo
October 26, 2011 at 9:22 pmUnfortunately Recuva is unable to recover files that have been directly overwritten with the same name.
That doesn’t mean the data is gone as you can never be sure Windows used the same sectors to write the new file to. Most programs, when overwriting a file do a delete and create a new file, it’s not a write-in-place just because file names match; it’s why the possibility exists.
You may be able to use some demos of more expensive professional recovery software to scan your drive for the file. At this point I would install the drive into a different system so you know data isn’t being written on it as you download and install all these recovery programs; basically using another system to scan the offline drive.
Hideaki Ogiwara
October 26, 2011 at 11:27 pmI think I will do it my work over again….
Thank you very much. I will be really careful from this time to save my session…
Ann Bens
October 27, 2011 at 10:38 amYou might want to consider using the option Save a copy (to another disk) as Auto Save overwrites itself after a number of times.
Adobe Certified Expert Premiere Pro -
Jeff Brown
October 27, 2011 at 7:37 pmAs I started when computer editing was even less reliable than it is now, my projects all get incrementally saved (manually) as I work on them. So, in my project folder, I’ll have “myEdit_01.pproj, “myEdit_02.pproj”, “myEdit_03.pproj”, etc. I also have a “myEdit_bak.pproj”, which is a duplicate of whatever the most recent version is.
And these get backed up nightly, too…I still overwrite projects occassionally. But I have the “myEdit_bak.pproj” to load, then re-save with the proper name. It has saved me from much weeping.
-Jeff
Hideaki Ogiwara
October 27, 2011 at 7:48 pmYes, I should do it like you from next time!
Now, I have to work everything from begging again… It is such a nightmare for me…T.T
