Activity › Forums › Media 100 › Wrong “Document Kind”
  • Wrong “Document Kind”
    Posted by Jaeson Koszarsky on May 4, 2007 at 8:25 pm
    Here’s what happened:
    I usually title my files as
    CLIENT.PROJECT
    CLIENT.BIN
    CLIENT.PROGRAM
    I accidentally started out by saving my PROJECT as CLIENT.PROGRAM, so I just did a SAVE AS and renamed it CLIENT.PROJECT. Then when I created a NEW PROGRAM and saved it as CLIENT.PROGRAM, it asked to replace/cancel and I replaced. The bin is fine.
    The problem is that somehow the meta-data didn’t change and the program file is showing its document kind as a project file and the Media100 refuses to open the program because of it thinks the file is a project.
    How can I change the meta-data so that Media100 correctly sees this as a program file and not mistake it for a project? I’m using MacOSX10.4.9.
    Jaeson K.
    Mike Laur replied 19 years, 5 months ago 3 Members · 7 Replies
  • 7 Replies
  • Floh Peters
    May 4, 2007 at 8:58 pm
    [jaesonk] “The problem is that somehow the meta-data didn’t change and the program file is showing its document kind as a project file and the Media100 refuses to open the program because of it thinks the file is a project.”
    Are you sure it is a program? I
  • Jaeson Koszarsky
    May 4, 2007 at 9:11 pm
    This is an old project that was archived and recently restored so there’s no backup saved in the usual place anymore. This has happened a few other times so I recalled what must have occurred. I usually correct the problem by doing a SAVE AS to create a new program file before exiting Media100. This project must have slipped by the usual fix.
    If I can change the file’s meta-data, I think it will open up. The PROJECT documents are usually smaller the the PROGRAM documents. That’s the case with this situation too so I’m guessing it’s a PROGRAM file with just incorrect meta-data.
    Jaeson K.
  • Floh Peters
    May 4, 2007 at 9:14 pm
    Then try holding COMMAND and Option while dragging the Program file on the Media 100 icon in the dock. If it is a valid program it should open up.
  • Jaeson Koszarsky
    May 4, 2007 at 10:02 pm
    Command Option dragging onto the icon won’t work either. Media100 still thinks it’s a project and says that a project is already open. If no project is open and I try to open the file is says there is a parameter error.
    This like an uncooperative PhotoShop if the file extension isn’t to it’s liking, at least there’s an open as or you can rename the extension correctly.
    I can’t find a way to edit the meta-data that determines the document kind.
    If I open the program file with the text editor, it’s mostly garbage characters but enough is readable to indicate that it’s a program file and not a project file.
    Jaeson K.
  • Floh Peters
    May 4, 2007 at 10:16 pm
    Download “Quick Change” (e.g. search for it on MacUpdate). Media 100 Programs should be Type M1pg, Creator M1SW for Media 100 sw…
  • Jaeson Koszarsky
    May 4, 2007 at 10:24 pm
    EXCELLENT! QuickChange worked its magic and the program opens up now. Thanks Floh! Have a good weekend.
    Jaeson K.
  • Mike Laur
    May 6, 2007 at 9:31 pm
    Again, Floh opens his magic window.
    I never even knew I needed to know such knowledge.
    ML
