Activity Forums Adobe After Effects Writting with light and burning holes
  • Writting with light and burning holes
    Posted by Ken Latman on May 16, 2009 at 12:30 pm
    I swear I saw a tutorial before that showed either lightning writing or engraving into a floor or wall based object. Over at MaxAfter there is one on making like a spark arc weld that cuts out a word sorta like an arc weld with trapcode particular. What I’m looking for is how to make that fluttering glow around the tip torch. Just to add a little bit more of an effect.
    I know Aharon has a tutorial on how the sprint commercial works but I’m looking for that cutting a piece of metal out with an arc welder.
    Any ideas?
    Michael Szalapski replied 17 years, 4 months ago 2 Members · 3 Replies
  • Michael Szalapski
    May 17, 2009 at 3:09 pm
    I’m not quite sure what you’re asking for, but it sounds like you could just put a lens flare on there. You might want to colorize the flare layer to make it match the cutting light. Then for the brightness of the flare put a wiggle expression so that it flickers.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Ken Latman
    May 17, 2009 at 6:48 pm
    I think that was exactly the tip I was looking for. Thanks great Szalam!
  • Michael Szalapski
    May 18, 2009 at 4:33 pm
    No problem. Thanks for letting us know that it worked.
    – The Great Szalam
