Activity › Forums › Adobe After Effects › Write-on very slow to display
  • Write-on very slow to display
    Posted by David Cabestany on October 30, 2013 at 3:03 pm
    I have a comp with tow instances of the write-on effect, the position of each is linked to individual nulls that mimic and hand drawn movement.
    Even when the layers soloed it takes a long time to render a single frame, I have a fast machine with enough ram and vram, so I don’t know what could be causing this.
    Anyone has had a similar experience?
    David Cabestany replied 12 years, 10 months ago 2 Members · 3 Replies
  • Kevin Camp
    October 30, 2013 at 11:13 pm
    to see if the expression is causing the issue, try converting the expression to keyframes (animation>keyframe assistant>convert expression to keyframes).
    it won’t delete the expression, just disable the expression, so if you need it back just re-enable the expression (click the ≠).
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kevin Camp
    October 31, 2013 at 8:55 pm
    it could also be that the brush spacing value is very low, forcing the effect to draw more dots than it needs.
    you could try to increase the spacing until the line starts to break up into a string of dots.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • David Cabestany
    November 7, 2013 at 10:21 pm
    Yes, that was it, thanks. However even with the smallest spacing value possible I’m still getting the string of dots and not a continuous line. I guess I’m stuck with this because I don’t want the line to be thicker than it is right now.
    David.
