Activity Forums Adobe After Effects Write-On Effect on 2 solid layers, however, only one layer renders
  • Write-On Effect on 2 solid layers, however, only one layer renders
    Posted by Jamar Bromley on January 30, 2019 at 9:28 pm
    In our composition, we have two discrete 3D solid layers, each one with a Write-On effect.
    The effect works exactly how we want it; however, only one renders at a time in the viewport and in an exported render.
    The solid layer that was made first seems favored.
    The second one renders only if the first one is turned off.
    Has anyone come across this issue / is there a solution to this?
    Jamar Bromley replied 7 years, 7 months ago 2 Members · 2 Replies
  • Greg Gesch
    January 30, 2019 at 11:10 pm
    Hi. Does it still happen if the Brush Positions aren’t pickwhipped?
  • Jamar Bromley
    January 31, 2019 at 3:54 pm
    yup, same thing, only one is rendering
