Activity Forums Adobe After Effects Write on effect
  • Write on effect
    Posted by Kevin Herrin on August 19, 2005 at 5:09 pm
    I am trying to use the write on effect for a blueprint and there are a lot of corners on the drawing. I have the path drawn out for write on to use but it can’t seem to handle the corners. It looks like it has bezier keyframes where the corners are curved. I can’t figure out how to chage it so the brush can follow a corner exactly.
    thanks
    Kevin
    Yoondo replied 21 years, 1 month ago 3 Members · 3 Replies
  • Steve Roberts
    August 19, 2005 at 6:25 pm
    Instead of using write-on, draw a mask, then apply effect>render>stroke. Animate the stroke’s end point.
    Steve
  • Kevin Herrin
    August 19, 2005 at 7:07 pm
    Hey good idea! I will give that a try.
  • Yoondo
    August 20, 2005 at 12:51 am
    Hey, that’s a lesson from an expert, not an idea.
