Activity Forums Apple Final Cut Pro Legacy Wow Something wrong in Compressor
  • Wow Something wrong in Compressor
    Posted by Chris Borjis on September 25, 2007 at 7:17 pm
    anyone notice when you export from fcp to compressor now (final cut studio 2 with the apple updates and latest quicktime)
    that your DVD’s look terrible? (huge macroblocking)
    but when you export the timeline to its own file an encode its ok?
    I wonder if thats related to the “connections” aspect of fcs.
    Chris Poisson replied 18 years, 11 months ago 5 Members · 6 Replies
  • Walter Biscardi
    September 25, 2007 at 8:04 pm
    I never use Send to Compressor because it’s always slower than exporting a reference movie. Didn’t know about this issue though.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Mark Maness
    September 25, 2007 at 8:08 pm
    [Borjis] “anyone notice when you export from fcp to compressor now (final cut studio 2 with the apple updates and latest quicktime)
    Yes… I did notice this.
    I will respond by saying that it is best to export and use compressor to compress your DVD for you. OR….. This is what I started doing… I only need to export a program (one program) and put it on DVD. So, to save time, I started using DVDSP to compress my Quicktimes Single Pass 7.0 mb/s. So far, the images are incredible and fast on my Mac Pro.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
  • Mark Maness
    September 25, 2007 at 8:10 pm
    How are your export and compression times?
    Mine were terrible. I have to export the entire program to a Quicktime, then I can make my DVD from that in a reasonable amount of time.
    Wayne Carey
    Schazam Productions
  • Sean Oneil
    September 25, 2007 at 8:51 pm
    I’m having problems as well. Compressor can’t figure out the right field dominace for 1080i source.
    Seems to have started after the Quicktime 7.2 update.
  • Chris Borjis
    September 25, 2007 at 10:09 pm
    [Sean ONeil] “I’m having problems as well. Compressor can’t figure out the right field dominace for 1080i source.”
    I’ve noticed this as well but with SD material.
    If I capture it then compress it, compressor gets the field order wrong. I had to make a preset and force upper field first to get this to work. Directly from final cut timeline it works fine. Problem only occurs when I drop captured media to a dvd preset.
    I realize a lot of people prefer to export timelines first then run compressor because it is faster but my main business is :30 second TV spots and some long form.
    TV spots take mere minutes to compress so why create more work for myself? Also a lot of times I have DVD’s due the next day and I would have to come back to work after exporting a long timeline then drop it in compressor. If I sent to compressor for final cut I can rest easy knowing when I come into work the next day its finished though it may have taken longer to do.
  • Chris Poisson
    September 26, 2007 at 12:22 pm
    My take on this, sending to Compressor from FCP WAS the best way in terms of quality, as it skipped a step of recompression, which is why it takes longer. I say WAS because this was true in earlier versions, and covered in the 4th section of this excellent article.
    https://www.kenstone.net/fcp_homepage/compressor_warmouth.html
    I have always sent a movie to Compressor like many above, because of the time factor, and tweaking the setting is not that hard, and I get great results.
    I will throw out though, As much as I like Compressor, EpisodePro has come a long way, and it’s 5Mb setting is just amazing for SD DVDs, quality is astounding.
    Have a wonderful day.
