Activity › Forums › Adobe Premiere Pro › Would someone explain step by step how to setup an external monitor?
  • Would someone explain step by step how to setup an external monitor?
    Posted by Perry Cheng on February 21, 2006 at 2:01 pm
    i.e. how to setup an NTSC monitor to make sure color, contrast and brightness is correct/fit for TV? Is there a device or color bar or something that can be done? Thanks in advance.
    Perry
    Erik Pontius replied 20 years, 7 months ago 3 Members · 2 Replies
  • Aanarav Sareen
    February 21, 2006 at 2:47 pm
    You can purchase professional televisions that cost around $500 for a 13″. That would probably be the best solution. Other than that, color bars can be used to set up your screen. There are various step-by-step guides on the net that go over calibration techniques. Search for “calibrating a tv with color bars” and choose the method you are most comfortable with.
    Aanarav Sareen, ACE
    Adobe Certified Expert, Premiere Pro
  • Erik Pontius
    February 21, 2006 at 4:32 pm
    The guys at Synthetic Aperture wrote a white paper on it.
    https://www.synthetic-ap.com/tips/index.html
    Click on the “Calibrating Video Monitors” link under the “Digital Video” section for a PDF.
