Activity › Forums › Adobe After Effects › Would shooting 3D on a RED Epic and a RED Scarlet work?
Posted by Mike Glasz on May 10, 2013 at 3:29 amI would like to shoot 3D and have access to a RED Scarlet and a RED Epic. If I rented a 3D mirror rig and set the Scarlet to 4K, would shooting in 3D work? Would it screw up in post because they are not identical cameras?
Walter Soyka replied 13 years, 4 months ago 3 Members · 4 Replies -
Walter Soyka
May 10, 2013 at 7:55 pm[Mike Glasz] “I would like to shoot 3D and have access to a RED Scarlet and a RED Epic. If I rented a 3D mirror rig and set the Scarlet to 4K, would shooting in 3D work? Would it screw up in post because they are not identical cameras?”
Scarlet and Epic have different-sized sensors. If you put the same lens on each, the field of view of each camera would be different. This would be an absolute nightmare for stereo.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Angelo Lorenzo
May 12, 2013 at 6:42 amActually, the Epic and Scarlet have the same physical sensor size. There are cost optimizations in the quality of the Scarlet’s build and the specs of internal components that attribute to the cost reduction.
Frame size is 27.7mm (h) x 14.6mm (v) = 31.4 mm (d)
Angelo LorenzoNeed to encode ProRes on your Windows PC?
Introducing ProRes Helper, an awesome little app that makes it possible
Fallen Empire Digital Production Services – Los Angeles
RED transcoding, on-set DIT, and RED Epic rental services
Fallen Empire – The Blog
A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
Can your post production question fit in a tweet? Follow me on Twitter -
Angelo Lorenzo
May 12, 2013 at 6:44 amThis is more suited for reduser.net as there are some RED engineers and 3d shooters who frequent the forums.
While the cameras are similar, down to the sensor being the same piece of hardware, the supporting processing boards are not. It’s a bit out of my wheelhouse but some of these optimizations may affect image quality to the point of it not being a suitable pair for 3D.
Walter Soyka
May 12, 2013 at 8:21 am[Angelo Lorenzo] “Actually, the Epic and Scarlet have the same physical sensor size.”
Gah, I stand corrected — I don’t know what I was thinking. Angelo, thanks, and Mike, I apologize for my error!
Walter Soyka
