Activity › Forums › Square Box CatDV › Workspace
Workspace
Posted by Pierre Valliere on May 31, 2016 at 2:26 pmIs there a way to save workspaces?
Dougal Matthews replied 10 years, 3 months ago 3 Members · 4 Replies -
Dougal Matthews
June 1, 2016 at 2:17 pmhi Pierre
there is an edit option in the workspace menu you can create / copy / customise workspaces here in catdv 12 we are introducing a better GUI to manage workspace configuration
we can also build custom workspaces as part of our professional services offering
https://www.squarebox.com/professional-services/
thank you Dougal
Improvise Adapt and Overcome
Steve Roessler
June 2, 2016 at 2:10 pmCan you be more specific. I have the same question as Pierre. How do you create / copy / customize workspaces. When we select the edit option we only see Help Defaults Cancel and Okay. There does not appear to be an option to create or save.
Steve Roessler
June 2, 2016 at 2:25 pmI think we figured out a solution. Logging in as Admin and then in the Preferences we went in to field definition and saved our field definition set.
Dougal Matthews
June 2, 2016 at 2:59 pmhi Steve
Glad you got it sorted
to edit / change most view / config options for a production groups you would need to be either an admin user or have “system Administration” rights.
thank you dougal
