Activity Forums VEGAS Pro Working with photoshop
  • Working with photoshop
    Posted by Joao Souza on January 8, 2012 at 10:21 am
    I created a lamp in photoshop and used BLENDING OPTIONS to create a light effect,saved it to compuserve(cause I want no background with that lamp )but when I add it to vegas, those blending options effects weren’t there so I guess I should have saved it to another format but which one cause I want that lamp with no background, I mean with a transparent background?
    If I save it to jpg, there’ll be a black background and when I add it to vegas, that black background will cober all other pictures I have there.
    I hope I made myself clear enough with my english.
    Thanks 😉
    Joao Souza replied 14 years, 8 months ago 5 Members · 9 Replies
  • 9 Replies
  • Joao Souza
    January 8, 2012 at 10:52 am
    It worked with PNG so is there any tip you guys could gimme?
  • Graham Bernard
    January 8, 2012 at 12:53 pm
    Vegas will successfully import PSD layers. I work in Corel and I can add adjustment Layers, but I need to save each Layer. I don’t get the adjustments.
    Grazie
  • Joao Souza
    January 8, 2012 at 1:39 pm
    What are adjustments layers?
    And what do you mena by you don’t get the adjustments?
  • Graham Bernard
    January 8, 2012 at 2:13 pm
    I can adjust layers in Corel using Adjustment Layers. But those Adjustment Layers don’t import into Vegas, only the results of using the Adjusment Layers in Corel.
    Grazie
  • Mike Kujbida
    January 8, 2012 at 4:12 pm
    Stick to PNG (my preference) or any other format that supports an alpha channel.
  • Joao Souza
    January 8, 2012 at 6:18 pm
    thanks Mike.
  • Frank Stevn
    January 8, 2012 at 11:42 pm
    JPG doesn’t alpha channel (transparency). File formats that support transparency include GIF, PNG and TIFF.
    You can add Photoshop files (PSD) to Vegas time line.
    If you add Photoshop files using right click if you need to add Photoshop layers as Vegas tracks.
  • Scott Roberts
    January 9, 2012 at 2:46 am
    For an alpha channel to work, you’ll need to make a mask in photoshop, then save that mask in the channels palette by duplicating it. Then save your image as a Targa and check off “Alpha Channels” in the save dialog box.
    I created a quick video tutorial: https://youtu.be/aXqLaDDXvGs
    LittleBlackBird.net
    My Blog
  • Joao Souza
    January 9, 2012 at 4:05 am
    Why would I do all that stuff?
    I mean I just wanted to save any picture with a transparent background,
    Once I discovered jpg can’t save transparecy, I save it as PNG and it worked.
    Before that, I tried to save it as GIF but it didn’t save those blending options effects with my pic.
    I just didn’t know to what format I should save a pic with transparent background and bllnding options effects.
