Activity Forums Apple Final Cut Pro Legacy Working with Many AVCHD Clips in FCP
  • Working with Many AVCHD Clips in FCP
    Posted by Emma Degraz on August 25, 2013 at 5:14 pm
    Hello
    I was wondering if people have any tips for working with tapeless footage when you have up to hundreds of very short clips from one event. Do you keep the clips separate, dump them to a sequence, and copy and paste from there? Do you dump them to a sequence, then export them out so they are all in one long ProRes file? Is there a plugin or converter that will merge the clips for you?
    Thanks in advance!
    Rainer Wirth replied 13 years ago 4 Members · 5 Replies
  • Steve Eisen
    August 26, 2013 at 3:04 am
    Why would you want to merge all the clips into 1 clip? Edit each clip separately.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Emma Degraz
    August 26, 2013 at 1:17 pm
    Sometimes I’ll have 30 10-30 second clips from one event, and it’s easier to quickly scroll through them when it is merged into one clip, rather than having to select each short clip one at a time to view it
  • Bret Williams
    August 26, 2013 at 1:23 pm
    You could nest them all in a sequence and use that as your source. No reason to export a file and be destructive.
  • Steve Eisen
    August 27, 2013 at 4:45 am
    Nest the clips or create a sequence called raw footage, place all footage into sequence and scroll away. The last thing you want to do as an editor is to learn bad habits.
    Steve Eisen
    Vice President
  • Rainer Wirth
    August 28, 2013 at 12:36 pm
    Hi Emma,
    I won’t transfer the clips in one big clip. What I always do – I transfer the clips into Prores, but each of them seperate with mpeg streamclip. With this program you can also make one big clip.
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
