Activity › Forums › Apple Final Cut Pro Legacy › Working with HDV, Pro Ress 422 or BlackMagic JPEG
  • Working with HDV, Pro Ress 422 or BlackMagic JPEG
    Posted by Arturo Celleri on March 19, 2010 at 11:21 pm
    Hello again,
    I’m recording a shoot today with 3 different cameras for different angles that I will sync in post production. I know this is a long and tedious process, but it’s what I have right now to work with so I’ve decided to go for it. I don’t want to be stuck in a post production nightmare so I am looking for the best route to take.
    I have two cameras recording real time to Final Cut Pro. One camera(CAM 1) is going to my Mac Pro via HDMI cable to a Black Magic Instensity Pro card. Another camera (CAM 2) is going via firewire to my MacBook Pro . The 3rd camera will record to it’s own hard drive for import later. (AVCHD camera CAM3).
    I’ve noticed that recording to HDV format is the smallest file size, and I can do that with CAM 1 and CAM 2. I’ve seen recomendations to use Black Magic JPEG buty I can only record with CAM 1 to that format.
    I was thinking of recording CAM1 to Pro Res 422, and CAM1 to HDV (only option via firewire), and then importing footage that I want from CAM3 as Pro res 422.
    CAn anyone give me feedback on if this is going to be a problem when I go to edit in FCPro 6 or if they have any better ideas with what I have.
    Arturo
    Michael Gissing replied 16 years, 6 months ago 2 Members · 1 Reply
  • Michael Gissing
    March 19, 2010 at 11:50 pm
    [Arturo Celleri] “and CAM1 to HDV (only option via firewire”
    I believe you can record ProRes 422 from HDV via firewire. Chris Poisson wrote a tutorial here at the Cow a while ago that outlines this procedure. At the same time, I would record to tape as a backup.
    Given the mixed formats, if you can standardise on ProRes 422 that will give you the cleanest post workflow.
