Activity Forums Apple Final Cut Pro Legacy Working with HDV
  • Working with HDV
    Posted by Renata on June 21, 2007 at 2:22 am
    Hi!
    I’m working with HDV for the first time. After a lot of research, I thought I had it figured out. But now, I’m trying to export a still image of a clip and it’s anamorphic! Does anyone know what I could do?
    My settings are the following:
    The material is 16:9 and I’m capturing it native.
    Sequence and Capture Device: HDV setup.
    VTR Sony 1080i is set to squeeze but I also tryed edge crop and it made no difference.
    Can anyone help? Thanks.
    Renata
    Jerry Hofmann replied 19 years, 2 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    June 21, 2007 at 1:54 pm
    I think you should be able to put the frame you want to export in a sequence which isn’t anamorphic such as uncompressed HD… then export it from there.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
