Activity Forums Blackmagic Design Working with fcp 24@25 makes video stutter.. (movie editors ??)
  • Working with fcp 24@25 makes video stutter.. (movie editors ??)
    Posted by Anders Haavie on September 10, 2006 at 3:44 pm
    Editing a film shot at 24 frames and put on dv tapes. When i use FCP and output with my decklink HD card I can’t make the smoothing 24@25 pulldown work. The picture stutters really bad. However, using firewire and my dsr-11 deck as a converter everything looks nice. This is my first movie project.. Doesn’t decklink support this option ??
    (PAL material, Quad G5, Decklink HD Extreme)
    Anders
    Xraid-Xserve-Xsan-Xeverything
    Anders Haavie replied 19 years, 11 months ago 4 Members · 5 Replies
  • Mark Burton
    September 12, 2006 at 7:47 am
    Interesting. I wondered if the 24@25 pulldown method would only work with firewire out. I wonder if BMD need to implement it in their drivers?
  • Anders Haavie
    September 12, 2006 at 8:48 pm
    Looks like it simply doesn’t work with decklink cards.. VERY annoying. Lets hope the blackmagic guys manage to make it work… please please please
    Anders
  • Mactrix
    September 14, 2006 at 7:49 pm
    It shutters also with the AJA Io … they don’t understand again upper and lower mixes in PAL …
    24@25 in DV should be lower
    24@25 in uncompressed should be upper
  • Rupert Watson
    September 22, 2006 at 5:04 pm
    So,is the answer that the only way to get a true 24fps edit to tape when working at SD 625 with 24fps film is to output to tape via firewire using System Settings/Playback Control/Pulldown Patteern/24@25 ?
    If you try to output via Decklink or AJA you get stuttering when playing a true speed 24fps ETT to 25fps tape.
    I guess the answer is to telecine to HD and capture DVCProHD or MotionJPEG @24fps and stay at 24fps all the way or get the rushes telecined to 30NDF digibeta and follow an NTSC SD workflow
  • Anders Haavie
    September 25, 2006 at 7:04 pm
    Yes
