Activity Forums Adobe After Effects working with cineon files
  • working with cineon files
    Posted by Serj Bato on May 4, 2007 at 3:55 am
    how do you guys work with cineon files? any tips on the log to linear conversion to use it for compositing and then outputting it using linear to log conversion.
    thanks
    Serj Bato replied 19 years, 4 months ago 2 Members · 2 Replies
  • Peter O’connell
    May 4, 2007 at 5:17 am
    Hi, here are a few tips. Make a 32 bit project. Working Space:None. Enable linear blending. Set the initial LOG to LIN converter on your cineon sequence to have a highlight rolloff of 0 (not 20 which is the default). Otherwise the whites get clipped at 1. Bring all you elements together inside a linear comp. Once you are ready to render, drag that comp onto the make new comp button and apply a LIN to LOG instance of the cineon converter effect.
    In this way you can roundtrip cineons with absolutely no shifted pixels.
    In my opinion you should avoid using a color management workflow with cineons (At least I can’t get it to work losslessly).
    Good Luck
    Pete O’Connell
    http://www.barxseven.com
  • Serj Bato
    May 4, 2007 at 7:04 am
    thankS!!!
