Activity Forums Apple Final Cut Pro Legacy Working with Canon T3i HD footage and FCP X
  • Working with Canon T3i HD footage and FCP X
    Posted by Howie Young on July 11, 2012 at 12:08 am
    I was wondering if some of the forum members would please share their experiences if they have worked with and edited HD footage shot with the Canon T3i.
    Are there any problems transferring footage to the Mac?
    Has anyone worked with all the different frame rates the T3i offers?
    Have you experienced any problems out putting a final project?
    What have your final products been – on-line web videos, films, broadcast TV – and how have they looked?
    Could you share some links of your work?
    Thanks for your feedback!
    Howie
    María Lara replied 14 years, 1 month ago 3 Members · 5 Replies
  • Shane Ross
    July 11, 2012 at 2:45 am
    Wrong forum. This is for those of us clinging to FCP 7…
    FCPX is here:
    https://forums.creativecow.net/fcpxtechnique
    Shane
    Little Frog Post
  • Howie Young
    July 11, 2012 at 2:55 am
    Hi Shane,
    Thanks for directing me to the correct forum. I’ll post in the FCP X forum.
  • María Lara
    July 12, 2012 at 5:14 pm
    Hi
    sorry for my rotten english its not my native language
    I had worked with that camera and i hadn’t had problems at all, i convert my material to Apple pro res HQ an then import it to FCP and everything runs fine. Worked with 1920×1080 30p, and exported to H.264 not even messed with the codec settings and used Export- Using QTConversion
    Working with different frame rates its now a problem i have with the 60D and a H.264 exporting. I worked with the same workflow and its not seeing well the resulting video is jumping in the pannings. like its running good and then stops for and instant and then continues, notice if i manipulated the frame rate it went worst and if use Broad Band High it impruves but do not respect aspic ratio nor sizes.
    I guess i wasn’t given you a lot of help bit guess I’m in the same problem
    María
  • Howie Young
    August 11, 2012 at 6:39 am
    Hi María,
    Have you found a solution to this problem yet?
  • María Lara
    August 11, 2012 at 5:04 pm
    Not really mi client didn´t notice but what if this happens again? I had spoken to the ones that recorded and seems they may had recorded with 24 frame rate instead 30, my settings on time line and material used for editing are 30, maybe i didnt notice before the exportation to Appel Pro res LT if the H.264 original files were at that frame rate (24), but even though i have exported it to 30 right? wHATt could be the problem WITH THE EXPORTED MATERIAL
    Its a big doubt i will have forever until someone knows what hapenned. I had spoken to editors, read about the proper exportations, tried exporting QT and then using mpegstreamclip and then converted to mpeg4 i mean i had done everything that is in my power
    Had you solved the problem?
