Activity Forums Apple Final Cut Pro Working with 24 and 30 FPS in same project
  • Working with 24 and 30 FPS in same project
    Posted by Adam Berch on October 1, 2015 at 1:27 am
    HI,
    I have footage that was shot on 2 DSLR cameras. 1 was shot at 24 fps and the other was shot at 30 fps. and 2 H4N Audio Files.
    It’s all one job that I put on the same timeline after I edited it. Will these different Frame Rates affect the job in any way? I can edit using different frame rates, correct?
    Is there a way to make all of the 30 FPS footage be imported at 24 FPS to keep things the same? Or Vice Versa? Would I have to do anything to the audio on import as well if I do this?
    FCP 10.2
    Jeff Kirkland replied 10 years, 12 months ago 2 Members · 1 Reply
