Activity Forums Apple Final Cut Pro Legacy Working w/ 23.98 HD and Final Cut Pro
  • Working w/ 23.98 HD and Final Cut Pro
    Posted by Johnnyp on February 11, 2006 at 6:03 pm
    Hello there:
    Here’s my deal:
    I’m TRYING to load in footage shot 1081i HD at 23.98 in to Final Cut Pro using a Kona LH card. The two problems I’m having are the following:
    1. When setting my capture preferences, I can’t find an option to compress the footage to save disk.
    2. When trying to capture, it’s dropping frames like crazy. I’ve disabled all drop frame warnings, so I can load something, but the palyback is horrible.
    HELP!
    Jp
    Johnnyp replied 20 years, 7 months ago 3 Members · 3 Replies
  • Shane Ross
    February 11, 2006 at 6:39 pm
    What drives are you capturing too? What format of HD is your video? What capture preset are you trying to use?
    For offline quality, try the DVCPRO HD codecs. Much less space required for that than uncompressed 10-bit.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Karim Zouak
    February 11, 2006 at 8:08 pm
    I agree — DVCPRO HD should be totally fine. What kind of disk are you capturing to? Firewire 400 will be too slow. Firewire 800 is not recommended, but I’ve never experienced any trouble with it.
    -karim
  • Johnnyp
    February 11, 2006 at 8:27 pm
    Capturing to an xRaid. The video was shot 1080i. Thanks for the input. I’ll give it a whirl!
    jp
